Going Over Driver Side Axle True Dual
Old Apr 24, 2008 | 06:30 PM
SuperSport01LS6's Avatar
Default Going Over Driver Side Axle True Dual
Im getting the flowmaster U-fit kit that has all the necessary pipes and then some for a full true dual setup from jegs. I went 3" piping and im gonna make the x in the normal location and run one side over the drivers side and one side over the pass. I saw One person just cut a notch out of there stock upper panhard rod to make this clear. if they can do it then i can too. Still indecisive of tips or no tips. Any suggestions or comments and concerns?? Ill have pics when the project is finished
Old Apr 24, 2008 | 07:16 PM
02silvaZ's Avatar
good luck, keep us posted
Old Apr 24, 2008 | 07:32 PM
kingdaveofblair's Avatar
Your going the same way I went. The U-fit kit is great, everything you will need and then some. I used 3" piping, and you could notch the upper pan hard par, but i didnt. No problems so far, but im going to make some drop brackets on bothsides for the lower pan hard bar so no hittin on the pipe occurs, even though right now im not having any problems. if you havent already bought the kit, pm for the best price you can get it for
Old Apr 24, 2008 | 08:38 PM
1320 killer's Avatar
interesting. don't forget to post pics.
Old Apr 24, 2008 | 09:14 PM
turbowhistle86's Avatar
I ran 2.5" pipe over the axles and no matter how much I adjusted, it always hit the lower PHB over bumps and uneven pavement.... I'm not saying you can't do it, but I finally gave up and went with the Corsa catback.
I hope you have better luck than I did!
Old Apr 25, 2008 | 08:38 AM
Yea I'll invest as much time as i can to make it perfect and have best clearence. What are your guys opinions on tips or should i just turn both tips down like my single 4" that i have on the car and keep it hidden?
Old Apr 25, 2008 | 12:38 PM
TFFMP's Avatar
I had 3" going over the driver side and it was a nightmare. Should have never tried it. I didnt have the mount notched nor was there a panhard relocation kit at the time. One of those might have helped.
Good luck with it
Old Apr 25, 2008 | 02:47 PM
INMY01TA's Avatar
I have never understood this fascination with true duals on an f body. I've heard lots of em and they dont sound much better, if at all, than most y pipe set ups. Power gains are minimal if not dumped before the axel too I believe.
Old Apr 25, 2008 | 02:54 PM
02NBMWS6's Avatar
I strongly disagree.
Old Apr 25, 2008 | 03:14 PM
BayAreaSS's Avatar
So do i. I have a friend that has a similat size cam as mine but he has a y-pipe setup and my car sounds a lot better than his with my duals
Old Apr 25, 2008 | 03:48 PM
headed-ws6's Avatar
I have true duels like what your talking about. the guy that did my exhaust cut a piece out of the upper panhard and the welded it to the upper panhard as stupid as that may sound it doesnt rattle is sturdy and lookes great.
Old Apr 25, 2008 | 04:15 PM
SladeX's Avatar
BMR Panhard relocation kit.
I run 2.5 inch true duals over the passenger axle. No clearance issues or things bumping. It's good for 3 inch true duals or a 4 inch pipe.
It's worth the investment if you are going true duals to simply go over the passenger side. If you go driver's side there's the off chance that each time you compress the suspension it will contact.
Old Apr 25, 2008 | 04:23 PM
02NBMWS6's Avatar
yes, that's what I did also. UMI also makes one now too
Old Apr 25, 2008 | 05:15 PM
Actually on my buddies 383 lt1 he had the same 4" mufflex on his single side like i do ..he put down 426 whp, that same day we built and installed a true dual x dumping before the axle and he put down 448.. i would say that an x pipe does something for sure especially over the 4" mufflex spintec combo! but everyone does have there own opinion i guess?
Old Sep 26, 2008 | 08:44 PM
James Montigny's Avatar
I'm interested in seeing pics of writeups people have RE: going over the driver's side.
It sure would make building my new setup easier. I want to run 11x14" chambered mufflers on both sides.
