NEED HELP - SLP LT Install
Old Apr 27, 2008 | 07:52 PM
WS-Six's Avatar
Default NEED HELP - SLP LT Install
Okay so i am having a bit of an issue with my SLP longtube install. I got the driver's side header in just fine, but i wasn't able to install the passenger side because of 2 strange reasons. The EGR hookups don't match the old manifold. I've got a few pictures below to show what i am talking about. I don't know how to make them fit, and i am not going to be deleting them all-together. Has anybody else ever run into this problem? I find it odd that SLP would make their connection at the wrong length and angle...any help would be greatly appreciated!!! And i need help fast, before i take my longtube to an exhaust shop and have them chop off and weld them correctly and make an extension for the bottom connection.
obviously the connections are different. See the 90 degree turn? AHHH!!
see both the hookups are different
This is how it hooks up on the factory manifold
how this thing lines up with the factory manifold
I don't even know how this is supposed to line up...non the less even know what it is...
Old Apr 27, 2008 | 09:44 PM
WS-Six's Avatar
Anybody!?!? Need help VERY soon!!!!
Old Apr 27, 2008 | 10:34 PM
RoDan's Avatar
I don't have a clue man, I used race style headers and deleted everything....good luck! ttt for you!
Old Apr 28, 2008 | 08:05 AM
03Sssnake's Avatar
Block off plates and have someone tune out the EGR/AIR.
Old Apr 28, 2008 | 10:30 AM
CAMAROZ28SS's Avatar
thats what i would do too. EGR/AIR is such a waste
Old Apr 28, 2008 | 10:50 AM
95GreenZ28's Avatar
Yea def get rid of it all.. air/egr
Old Apr 28, 2008 | 11:01 AM
sappertodd's Avatar
I took the egr off and everything works fine here is a link to help with the passenger side it was a SOB http://www.popularhotrodding.com/tec...all/index.html good luck man.
Old Apr 28, 2008 | 11:04 AM
Fb0dy0nly's Avatar
what everyone else is telling you. If your not in CA, just block it off and forget it even was a problem. You could even hack up some thin metal, drill some holes and bolt it on.
Old Apr 28, 2008 | 11:25 AM
Bad Blue WS6's Avatar
that is odd ,,,good luck on that one.
Old Apr 28, 2008 | 11:39 AM
2xLS1's Avatar
Your headers are for a 00 model. 98-99 EGR and AIR flanges are different than 00-02 with 01-02 not having EGR.
Old Apr 28, 2008 | 11:48 AM
TheSilverOne's Avatar
looks like the AIR tube was rewelded too. i'd def get rid of those headers.
