Throttle Body problem
its reading that its 1% open at idle. and I get a code that says (TPS out of range/ performace) so I put a new TPS on from GM. same thing. checked all connections there good, cleaned them too.
because it stays at 1% open it wont go into "idle mode" and idles like crap
but heres the kicker, after a hard run it will read 0% and idle great. but then it might read 1% and through the code while sitting at a traffic light.
is it my TB? I am getting the 92/92 setup but I need tires and axles 1st. so I would like to fix this now and it not be an issue.
any ideas would be great
Thanks
Mike
see when the car is not running the throttle postion reads 0% but its when I start the car it reads 1%
and I dont want to have the voltage reading to low if I ajust it more
Oh, you will need to grind off the position tab to be able to do this.
you can do this your self if you open the box where the cables go by twisting it all the way then with the other hand press down where the tb cable goes and see if it is open all the way . if there is slack in it you can adjust it by following the cable to about the middle between the box and the cable . there is a tab that is threaded you can pop off and adjust the tension .
so I was thinking I would check all the grounds on the motor to make sure I tighten them enough. because saying "a circuit" sounds like its not completing the circuit so I would think that would be a ground.
I am thinking that I may have just handtighten it and it has come loose from the shaking of the motor. because it will say 0% when the key is ON but as soon as I crank it over it jumps to 1% some times it doesnt and sometime it does.
well see tomorrow after work. Ill post if I find anything.
so I googled it and its says:
Description: code detects if the TPS is stuck.
Malfunction Criteria and threshold values: Actual throttle postion does not match RPM vs. predicted throttle postion look up tables.
so I dont know.........
Im stuck.......
searched for code P0121 and found its a MAP kPa is getting maxed out
so my tuner reset it and good to go.
no more code and car runs great
maybe it was doing it before I dont know, but its fixed now and time for a cage, and rear sway bar!
