Installed LS6 intake...
I simply used 1" pieces of 3/8" rubber hose, sliced lengthwise to go around the bolts. Loosen, lift them up, place the hose around the bolts....done deal. I never heard of using laundry clips...another good idea.
Just pull the entire fuel rail off as one complete assembly and move it over to the driver's side strut tower. As long as you are careful and don't kink or break the lines, it should be fine.
