Installing A Catch Can
Old May 3, 2008 | 11:08 AM
TORCHD 02 TA's Avatar
Default Installing A Catch Can
When you guys are installing your catch can, which hole are you mounting it on, on the passanger side head? The one on the left side towards the A/C canister? Or the one on the far right towards the intake?
Thanks
Old May 3, 2008 | 11:47 AM
rel3rd's Avatar
Here's where I mounted mine...Not in the way of anything.
Old May 3, 2008 | 11:59 AM
code4's Avatar
For oil? I installed a ls6 valley cover & hooked my hose to it, mounted the can on the passenger side fender then the other hose to the intake.
If you are going to use the valve cover I would use the passenger side. You will have to put a filter on the driver side for air flow.
Old May 3, 2008 | 01:08 PM
are you using the Mike Norris catch can or revextreme?? I thought that the hose with the PCV valve goes from the intake manifold to the top of the can?
Ohh yeah what size bolt are you using too?
Old May 3, 2008 | 02:35 PM
rel3rd's Avatar
That one's from Mike Norris. No idea of the bolt size. I think it was holding the EGR crap there originally...not positive.
Old May 6, 2008 | 05:29 PM
TLewis4095's Avatar
The lowest outer bolt hole for the RevXtreme bracket:
Old May 6, 2008 | 08:07 PM
DarkJuggalo's Avatar
i need one of these
Old May 6, 2008 | 08:48 PM
BlkBird2000's Avatar
i dunno what a catch can is
Old May 6, 2008 | 08:55 PM
hanzel69's Avatar
Word, what is the purpose of a catch can?
Old May 6, 2008 | 10:41 PM
Johns00Z28's Avatar
As many of you know, the PCV system on the 98-02 LS1's isnt exactly the greatest system on the planet.....burning up to 1 quart every 3K miles. How do you prevent the oil from entering your intake? Simple....install a catch can. Why do I need to prevent oil from entering my intake? When oil vapors exit the crankcase via the PCV valve, they enter the intake and create adverse effects such as carbon build-up on valves, pistons, and plugs, as well as cause harmful detonation. Detonation in many cases causes the ECM/PCM to retard timing, thus creating a reduction in horsepower. By removing this oil, a clean burning engine could help the environment as well as improving the performance of a vehicle.
A PCV catch can installs between your PCV valve and your intake manifold. It acts as an oil/air seperator. All of the oil mist that enters the can is trapped, and the air flows through the can, much like an A/C accumulator. You will be amazed to see how much oil catch cans can accumulate every few thousand miles.
http://www.ws6project.com/user_stor/...0a77b693dfc3dc
Old May 6, 2008 | 11:17 PM
hanzel69's Avatar
Cool, so sounds like a good thing to stick on there, that'll be my next mod.
Old May 7, 2008 | 08:21 PM
TLewis4095's Avatar
Excellent summary!
Old May 7, 2008 | 08:41 PM
Johns00Z28's Avatar
I just copied and pasted it from the link I provided. I know they could say it better than I could.....didn't want to make it seem like I wrote it...lol.
Old May 11, 2008 | 08:38 AM
Well i put the catch can on. drive it total 20 miles no oil yet
Old May 11, 2008 | 08:57 AM
junior28570's Avatar
I've had mine (revextreme) on for a couple hundered miles + several dyno pulls and a trip the the track ... 0 oil (checked it yesterday). I am kinda curious though .. I mean; how did all that oil get in my intake if it weren't going this route? I'm still getting a good deal of white smoke out of the exhaust @ WOT so .. I'm still a little lost as to where it might be coming from. It's a new engine build and gapped for a 150 shot, would that be a good cause for that much oil burn?
Old Nov 1, 2008 | 09:27 AM
frito1's Avatar
BOOM! I'm digging up some old threads
Is a catch can and LS1 PCV setup good enough for 7200 rpm? Or do I need the LS6 valley cover and catch can? I'm taking in a ton of oil right now with the stock PCV system!
Old Nov 1, 2008 | 10:03 AM
I would upgrade to the LS6 valley b/c, well, it is just better then put a catch can on. can't go wrong
Old Nov 12, 2008 | 02:45 PM
nickp650ss's Avatar
What kind of catch can did you use? What did the bolt size for mounting the catch can bracket end up being also? I'm burning at least 1 quart every thousand miles!
Old Nov 12, 2008 | 07:50 PM
99345hp's Avatar
Now that I've read this i'm thinking about this mod too. I dont burn that much oil, but what the hell. I think they add a little bit more in the looks department.
Old Nov 12, 2008 | 08:35 PM
ae13291's Avatar
i first installed my catch can and had no oil in the can for months so i tested it by squirting oil in the inlet while the car is started and sure enough that oil went right through the can and into the intake. now i set mine up with the vertical pcv mod along with a mini husky catch can and after that 2 fuel filters inline. now i catch a bunch of oil in the big can and i catch alot in the mini catch can. and the filters get oily every now and then, i also have a filter on the breather to the tb and that gets oily as well
