1998 tb on a 2002
Old May 6, 2008 | 09:45 PM
sspower's Avatar
Default 1998 tb on a 2002
Someone local is selling a used 1998 ported tb for the same price as it would cost me to get mine ported. So i was wondering if it would fit without any modifications.
Old May 6, 2008 | 09:47 PM
mvvette97's Avatar
You just have to change the shaft. Very easy to do.
Old May 7, 2008 | 01:32 AM
408trans_am's Avatar
Closed ex-Sponsor Account
like mvvette said, you can just change the throttle shaft, or you can put it on and just take some slack out of the cable. You can put a 98-99 on a 00-02 with taking slack out of the cable but cant put a 00-02 on a 98-99 or else the throttle blade will stay open.
Old May 7, 2008 | 10:58 AM
Bad Blue WS6's Avatar
you will also need to change the spring,,
Old May 7, 2008 | 09:11 PM
DiabloFormula's Avatar
I have a 2000 TB on my 98, only thing done is ported and polsihed no other changes and it works fine.
Old May 7, 2008 | 09:21 PM
no need to change the spring at all. All the 3 different springs are just slightly different rate. stiffest = orange>blue>brown or gray = weakest
Old May 8, 2008 | 08:18 AM
sure, you dont have to, but it wont respond at its best,,the short swing or long swing cam goes off the tension,,therefore, if your using the wrong spring, your getting the wrong tension for you cam.
Old May 8, 2008 | 04:22 PM
snake charmer's Avatar
i have used each one on my rife and it is hard to notice at first . stock my ride would be a blue spring , when i used a brown or dark spring tb it would idle high when coming to a stop especially at high speed . the orange is about the same and works with 98-99 rides or at least better than the blue spring . now i run a 90 and it is all good with the newer design .
