Is this catch can set up right?
Old May 8, 2008 | 06:22 PM
RippinZ121's Avatar
Default Is this catch can set up right?
Some pics in the search aren't that clear. (RevExtreme catch can)
Rubber tube going to the top of the catch can is in the yellow box. It is the piece that comes around from the back of the drivers side valve cover. Passenger side valve cover is blocked off.
Supplied tube is going to the side of the intake. Throttle body is blocked off.
Old May 8, 2008 | 06:26 PM
LS1-NAVY's Avatar
for installing thoes is all you have to do is cut that one line and put the can there i am lookin at these and dont know how to put it in
Old May 8, 2008 | 06:40 PM
bczee's Avatar
The catch can is ok that way.
IMO, You should reconnect the fresh air tube from the TB to the Valve cover.. else you are going to pull a lot of vacuum in the engine and most likely be sucking up a lot of oil into the catch can. The Fresh air port on the TB allow air into the engine and keeps high vacuum from being generated by the PCV port pulling air/vacuum.
Old May 8, 2008 | 06:57 PM
RippinZ121's Avatar
Ok I will add another line to the TB and the valve cover. Thanks guys.
