Need help with vacuum WITH PICS
1. not sure what this is suppose to connect to
2. this is how it came but i think the one on the right should be connect to radiator hose?
3.Not sure
4.im pretty sure this is correct
5.i have the brake booster connect to the vacuum in the back?
--first off pic one isnt supposed to have a PCV valve there.
--pic 1 is supposed to tie in with the hole on the back of the pass side valve cover, and they they both hook into the vacuum port shown in pic3
--pic 2 is your coolant crossover. Its supposed to tie into the top of the radiator to vent our air.
--pic 4 is correct, just need a hose that actually fits on the nipples.
--other capped of plug (on intake) in pic 2 was for your fuel tank pressure solenoid thing. you dont need that so it can stay pluged off.
Read this thread to help understand it all:
https://ls1tech.com/forums/showthrea...641&highlight=
If you want, you can call me during business hours & I'll try & walk you through each step.
Andrew69 was describing the stock OEM system & he is correct on that design....I was refering to the modified way we do it on strokers & modded motors.
A: has a PCV valve in place to controll the amount of vacuum pulled & act as a check valve,
B: has a non-restrictive filtered fresh air source for make up air & relief of excess pressure under high RPM's, and
C: with a good catch can eliminates the oil contamination of the intake charge.
Just ask if you get stuck on any of it.
