oil in the intake should I use a catchcan?
Old May 13, 2008 | 03:52 PM
sappertodd's Avatar
Default oil in the intake should I use a catchcan?
I have a few question that I need some help with my dd.
1) I took my lid and maf off and ran finger on the inside of the TB and I hae all kinds of oil onthe inside. So should I put a catchcan on it or what would be the best thing to do. I heard the LS6 PCV can actually make more power is this true? I don't know anything about these things so anything helps.
2) I put on the LS6 intake and block off the EGR and was thinking about do the same with the air. Will this add horse power or is it just a weight reduction? If you can send some links or pictures that would be great.
Old May 13, 2008 | 04:00 PM
99blancoSS's Avatar
Thumbs up
Yes you should, here ya go. Tell Tracy that blanco sent you
https://ls1tech.com/forums/showthrea...+revxtreme+pcv
Old May 13, 2008 | 04:11 PM
03Sssnake's Avatar
I 2nd that! My revextreme catch can should be here tomorrow or thursday!
Old May 13, 2008 | 11:42 PM
stevied916's Avatar
I installed a ls6 valley cover...it helped alot and cleaned up the engine bay a little because you ditch all the stock pcv lines from the valve covers
Old May 14, 2008 | 01:31 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The LS6 pcv took care of my problem on my old Z28. I have never been a fan of adding more stuff under the hood.
Old May 14, 2008 | 08:52 AM
tylerdj's Avatar
I'll be going with the ls6 pcv too.
Old May 14, 2008 | 09:13 AM
99blancoSS's Avatar
I went with the lS6 setup in my 347 and it didnt stop the oil from getting into the intake and so I ran a catch can as well. Lot more work to the ls6 v
Old May 14, 2008 | 09:16 AM
radz282003's Avatar
I have added a catchcan and two inline seperators after. I don't get any notable oil now ;D
Old May 14, 2008 | 09:28 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I use a catch can and love it.
Old May 14, 2008 | 02:01 PM
LPTXZ28's Avatar
I was using a filter on the oil filler cap and PCV delete but got tired of the oil dripping down on to my headers. I just installed my REV extreme can and it is a bit larger than I expected but seems to do a great job.
Old May 15, 2008 | 09:18 AM
KILLERARMY's Avatar
Love my RevXtreme catch can.
Old May 15, 2008 | 09:22 AM
99blancoSS's Avatar
It is an excellent product, I'm going to be carrying them as well now. SO now you can either get a hold of Tracy at RevXtreme of contact myself to get one of these great catch cans.
Old May 15, 2008 | 11:24 AM
junior28570's Avatar
Is there any other way for oil to enter the intake other than the PCV line at the TB?
Old May 15, 2008 | 11:47 AM
99blancoSS's Avatar
valve cover has a vent line going to back of tb, labeled vent tube in this picture
Old May 15, 2008 | 12:34 PM
proelky's Avatar
Have you tried running the redesigned PCV valve? I believe it's a 12562717, it may be 1257xxxx. Anyway it is pretty much a flow through design that was made to fix the oil consumption problem on the 6.0L's. I'm running it on a 408 with 11.1, and a crankcase breather with no blow by.
