FAST 90 intake question?
Old May 21, 2008 | 05:46 PM
davered00ss's Avatar
Moderator
Default FAST 90 intake question?
I know you can change the 78 upper intake to a 90mm upper intake.
My question is, are the lower & middle intakes the same on both, or different & the upper just fits on the other parts as well?
Old May 22, 2008 | 12:06 AM
Kingc8r's Avatar
Interested as well but I don't think you can buy Fast 90 products anymore since they've been discontinued
Old May 22, 2008 | 12:32 AM
LS184's Avatar
wht? yes u can buy fast products !
Old May 22, 2008 | 06:57 AM
Moderator
The 90 has been discontinued, not FAST products.
Old May 22, 2008 | 07:31 AM
radkon's Avatar
The 78 and 90 parts are interchangable, the only difference is the top shell (with TB opening), not sure about the "new" 92. I know because I've done it.
Old May 23, 2008 | 09:00 AM
Moderator
What do I need for new gaskets to do the swap?
Just the TB gasket or is there a top shell gasket?
Old May 23, 2008 | 09:54 AM
ICRAZY6's Avatar
There is a gasket between the shells. As long as you don't damage it your good. The new upper shell should come with the TB gasket.
Old May 23, 2008 | 01:46 PM
99zman's Avatar
and some black RTV..
Old May 25, 2008 | 11:07 PM
GGTTOO's Avatar
I just purchased a 90MM top on Ebay and installed the setup lst weekend. keep checking they have them from time to time. I only payed 120.00 for the top portion. It had the EVAP fitting busted off but other than that it was like brand new. I repaired it and actually with the new brass fitting it fits better on the car.
Do not take the bottom two sections apart and you will be fine in replacing the top.
