Removed LT's, Ory, and LS6 Intake, now car sputters??
I recently removed all the aftermarket parts from my 98 Formula, installed the EGR, LS1 intake, Factory Manifolds, etc. Even turned the tune back to factory settings. Im getting a slight sputter under throttle. It only happens when you open the throttle, and it balances out and runs fine shortly after.
I thought it was possibly a vacuum leak, I removed the LS1 Intake and swapped the Intake gaskets with freasher ones. I swapped EGR's with a known good one. still ran the same. I did however leave the Bosch 13111 Long O2's on the car. Could them have caused the problem? What else could it be??? Im stumped!
Thanks for looking,
Chris
Thanks for looking,
Chris
