New engine cooler + new fluid = water pump start to leak
Old 05-29-2008, 05:32 AM
tici's Avatar
Default New engine cooler + new fluid = water pump start to leak
This is about a 98 Trans Am, 10 years old, 90'000 miles.
I never replaced the coolant, never had a leak.
Last weekend I installed a LT1 cooler (they are 40% thicker than those installed in LS1 cars), flushed the system and filled it up with a local brand fluid.
The fluid is for aluminum engines, it's ethylene glycol based and gives the same freezing protection than the GM product.
Result: now the water pump is leaking from the shaft seal.
Coincidence?
The seal doesn't like the new fluid?
Flushing the system also removed a healthy layer of dirt that helped the pump to be sealed?
Thanks for any help
Stefano
Old 05-30-2008, 05:21 AM
tici's Avatar
t t t
Old 06-01-2008, 09:05 PM
Z28Red01's Avatar
How long did u leave fluid out of the pump? My dad flushed his system and left it dry for 2 days and the seals shrank and cracked.
Old 06-02-2008, 10:52 AM
tici's Avatar
Maybe 2 hours.
It is possible that when I refilled the system the pump ran dry for a short period of time, just what it takes for the system to be completely filled.
