Intake manifold..screw up!!
Old 05-29-2008, 10:43 AM
NJgunslinger's Avatar
Default Intake manifold..screw up!!
I am pissed, I pulled the intake manifold off my car and screwed up. I broke two pieces, the damn sensor connected to the back of the intake..so I a have to buy a new one of those...
And there is a piece that is connected to the block behind the Intake Manifold... Round piece that connects to a Sensor plug. I looks like its a big bolt that I cant remove...anyone know of this and know what size socket to use. This really sucks!
Its whats circled in white that broke off.
Old 05-29-2008, 10:50 AM
NBM-LS1's Avatar
The thing you broke off on the block I believe is the oil pressure sending unit. Things like these need to take time. You cant be rushed on this.
Old 05-29-2008, 10:53 AM
BlackSS2001's Avatar
that tall one is the oil pressure sensor. I broke mine also. I used a wrench to take it off. It's not a big deal and easy to fix.
Old 05-29-2008, 10:54 AM
Thanks...too late now for that..So I can just screw that off and put a new one on?
Also is the sensor that connects to the back of the intake the MAP sensor? part # 16212460?
Old 05-29-2008, 10:56 AM
Yep just take the broken one out and put in a new one. I got mine from a local GM dealer.
Yes that's your MAP sensor on the back on the intake.
NBM-LS1's Avatar
Yes that would be the map sensor in the round hole connected to the back of the intake.
NBM-LS1's Avatar
damn beat me. =(
Old 05-29-2008, 10:57 AM
haha I'm a quick one at least thats what she said
Old 05-29-2008, 11:03 AM
Anyone know the oil pressure sensor part number?
Old 05-29-2008, 11:04 AM
Hey, what size socket did you use to get the oil pressure sensor out, I dont have any big enough so I have to go buy it.
thanks
Ill try a wrench, not much room there
Old 05-29-2008, 11:09 AM
not 100% sure but I dont think you can even use a socket on it because the plastic has a larger diamiter than the base where you would use a socket.
I can't remember the size I used. you should have enough room. you intake is still off isn't it?
part number is 12562267
Old 05-29-2008, 11:11 AM
As far as your map sensor I have seen people epoxy them back on or plastic weld them.. I'm not sure how yours is broke but it might be an option for you.
Old 05-29-2008, 11:17 AM
HSV-GTS-300's Avatar
27mm or 1" + 1/16 socket......needs to be a deep socket to clear the plastic bit.
From the bottom of the hex on the sender to the top of the plastic breakable part is 2.7" tall.
Old 05-29-2008, 11:21 AM
motoo344's Avatar
It was pretty easy to get the broken oil pressure unit off. Just gotta get a big ratchet on there. New one will just screw on. If you have an autozone, just go to the counter and they will find the part for you. If they dont have it, it should only take a day and its about 35 bucks. I broke mine too! Whats the other thing you broke?
Old 05-29-2008, 05:21 PM
Datzneat's Avatar
Do we have a write up on the correct way to remove the intake manifold? lol
Old 05-29-2008, 06:12 PM
motoo344's Avatar
http://ls1howto.com/index.php?article=5
Pretty straight forward.
Old 05-29-2008, 06:22 PM
Datzneat's Avatar
Cool. I'll be removing mine for paint soon. I don't want to do what this guy did.
Old 05-29-2008, 08:32 PM
Glad I could be of help... Well parts are all back in..guess the bottom line is just take your damn time!
Old 05-29-2008, 08:33 PM
Datzneat's Avatar
Glad to hear ur back up and running!
