View Poll Results: Which intake should i go with???
SLP EGR Ls6 intake $550!
14
56.00%
BBK SSI 85mm for $400?
11
44.00%
Voters: 25. You may not vote on this poll
LS6 with EGR, or BBK SSI??
Old May 29, 2008 | 02:36 PM
1998LS1SS's Avatar
Default LS6 with EGR, or BBK SSI??
OK i want an intake with egr provisions...
ive been looking for a used slp ls6 intake with egr provisions for about 2 months now....
only way to get it is new for $550!!
or get the BBK SSI 85mm intake with the egr provisions for $400
nerver know maybe ill yous nitrous in the future too.
and will bbk intake bolt right up and fit the stock TB??
also heard that bbk is just slightly better than an ls6 intake.
IM IN CALI. EGR IS NEEDED!
Old May 29, 2008 | 03:16 PM
bigti99a's Avatar
eh there is some argument either way. there is probably only a few HP difference. people say the bbk heat soaks but is better if you want to spray. the ls6 stays cooler and flows as good or maybee better. i think the bbk works with all the stock stuff. i like my ls6.
Old May 29, 2008 | 05:56 PM
LPTXZ28's Avatar
I voted BBK, I just installed mine with 85mm TB and could tell a big difference above 3500 rpm from my LS1 intake. Installation is easy and it looks
Old May 29, 2008 | 06:13 PM
99SSragtop's Avatar
BBK are great to deal with. Just picked up some headers, fast service from Brothers performance and BBK head office them selfs.
Old May 29, 2008 | 07:07 PM
chevyguy7802's Avatar
LS6 got my vote......
Old May 29, 2008 | 07:11 PM
1fastz's Avatar
I am really happy with my BBK intake. Just remember that if you do upgrade to the BBK, it has a 85mm throttle body opening, so i would take advantage of that and get a Professional Products 85mm TB from Byunspeed.com for about 185.00
From a Corvette Online Magazine:
....after we installed the BBK SSI intake and matching 85mm throttle body, the peak numbers jumped to 489 hp and 450 lb-ft, for gains of 27 hp and 14 lb-ft. The BBK intake suffered no loss in power at any rpm compared with the stock LS1 unit, offering gains from 3,000 to 6,500 rpm, with significant gains occurring past 4,000 rpm.
http://www.vetteweb.com/tech/vemp_07...old/index.html
Old May 29, 2008 | 10:21 PM
LS1-NAVY's Avatar
ls6 flows awsome and im gonna be getting that. plus there is that heat soak myth with the bbk
Old May 30, 2008 | 12:49 AM
Soul TKR's Avatar
out with the old... in with the new...
Old May 30, 2008 | 02:24 AM
RrCoX22's Avatar
another thing you may want to consider if your keeping egr for emissions you may also want to consider the LS6 since it looks stock... the BBK will catch the eyes of most techs if not all
Old May 30, 2008 | 04:37 PM
1998LS1SS's Avatar
yeah so will it be a direct fit with everythig including emmisions?
i dont need to buy any other parts right since my car is an ls1 intake?
Old May 30, 2008 | 09:07 PM
RrCoX22's Avatar
normally a LS6 coolant line is provided with the LS6 manifold and block off plates for the rear inlets for the heads. Otherwise you would have to grind down the ribs on the LS6... don't know much about the BBK, would assume they have everything provided too
Old May 30, 2008 | 11:26 PM
GGTTOO's Avatar
I will sell my BBK IM and TB both 85MM for 425.00 plus shipping. They are listed in the for sale section. They are as new as one would look that has been installed. PM me if you are interested.
Here is the link: https://ls1tech.com/forums/showthrea...&highlight=bbk
Old May 31, 2008 | 06:30 AM
hokie00 TA's Avatar
ls6 just got mine the other day just waiting to install it now.
Old May 31, 2008 | 06:37 AM
95 Z28's Avatar
Good point. I say go for the LS6 because it's been proven to work great with almost any setup and personally I think that BBK looks under the hood.
Old May 31, 2008 | 09:23 AM
kct385's Avatar
I've got the SLP LS6 manifold. It's great so thats where my vote is going. The only problem I had with it is cutting the EGR pipe thing and using the new set up thing to get the pipe into the manifold but again it's minor.
Old May 31, 2008 | 09:24 AM
Pntbll309's Avatar
I installed my ls6 last night. Ill post gains in a few hours.
Old May 31, 2008 | 09:26 AM
transam98989898's Avatar
if weiand would ever come out with their intake I'd buy it and sell you my SLP LS6 intake with EGR for cheap...
Old May 31, 2008 | 09:55 AM
wannafbody's Avatar
You can use the EGR with the BBK.
Old May 31, 2008 | 11:21 AM
Datzneat's Avatar
Wow didn't think it would be this close. I'm for the BBK all the way.
Old May 31, 2008 | 06:24 PM
SOMbitch's Avatar
For $50 lingenfelter sells an EGR adpter for an LS6 IM. Install looks pretty easy. i was gonna go that route until I lucked into a deal on a 90/90
