Compressor seized, what should I replace?
Old Jun 3, 2008 | 11:37 AM
Muerte_X's Avatar
Default Compressor seized, what should I replace?
It actually happened last summer, but I just dealt with it. Now I'm really missing the cold air, lol.
Anyway, at some point the a/c gradually blew less and less cold over a couple days until it was blowing warm air. I assumed it was low on refrigerant and tried to add some, which didn't work because the guage said it wasn't low.
The next day, if I tried turning the a/c on, it would stall out the car. The compressor seized completly, anything that would turn the compressor on, would lock the pulley and it wouldn't turn. I finally decided to cut the belt, since it has it's seperate, and in case I wanted the air through the defroster vents that following winter.
So, I know I need a new compressor, but should anything else be replaced? Can I just swap in a new compressor and belt, and take to be serviced and have the shop vacuum out the lines and add refrigerant?
Old Jun 3, 2008 | 12:32 PM
bczee's Avatar
you should be ok with those items being replace.. but you might want to replace the dryer/filter.. they are not that much and would be a good idea anyway.
