motor mount torque
Old Jun 9, 2008 | 07:06 AM
aNuBiS's Avatar
Default motor mount torque
I did some searching and I found JRP's torque spec FAQ but Im not totally clear on what part is what. I need the individual torque specs for all the below
stock cast lower motor mounts 4 bolts to the stock k-member
stock upper motor mounts to the aluminum block
long through bolt & nut that joins the two
Old Jun 9, 2008 | 11:14 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Check the PDF file in this post
https://ls1tech.com/forums/showpost....20&postcount=5
Old Jun 9, 2008 | 12:08 PM
aNuBiS's Avatar
Ya, thats the exact chart I already have, and Im not quite sure which ones are the proper ones Im looking for.
Old Jun 9, 2008 | 05:40 PM
aNuBiS's Avatar
bump....
