best maf for stock
Old Jun 10, 2008 | 06:59 PM
lusting4ls1's Avatar
Default best maf for stock
is there anything such as a plug-n-play unit for a stock car? i was wondering if just the ported ends would do or i have also seen some using the corvette mass airs. is this a plug-n-play option?
the only mods right now is a lid and im about to order a ported throttle body and was just looking for a maf to go along. thanks
Old Jun 10, 2008 | 07:23 PM
02silvaZ's Avatar
just get the ported maf ends, work great, a bigger maf is not necessary unless we are talkin 500+ hp, most tuners have a better time tuning with the stocker also
Old Jun 10, 2008 | 07:33 PM
jetlag's Avatar
The best maf for stock is stock...no ported ends, no descreened maf..don't even look at it
Old Jun 10, 2008 | 07:34 PM
TORCHD 02 TA's Avatar
the stock MAF will handle 500 HP...
I have been thinking of getting a 85mm truck MAF though....
you need a 5 wire for that though, anyone know how to go about that
EDIT: i descreened mine. Some A4 cars when they descreen the MAF have problems and it seems the M6 guys don't have problems
Old Jun 10, 2008 | 07:37 PM
Shawn @ VA Speed's Avatar
x3 on the stock maf
Old Jun 10, 2008 | 07:55 PM
MrElectric03's Avatar
x4 for stock...money is better spent in other places. If you get heads and/or cam in the future go with a truck or Z06 MAF and have the car tuned.
Old Jun 10, 2008 | 09:40 PM
willinium's Avatar
can you use a z06 MAF on a 02 z28 ??
Old Jun 10, 2008 | 10:44 PM
stock it is. thanks everyone!
Old Jun 10, 2008 | 11:23 PM
AustinYukon's Avatar
I'm new to all of this stuff. How do I know what MAF I got when I bought my motor? the seller said it was a Z06 MAF I think.
Something about 85mm
Old Jun 11, 2008 | 05:46 AM
If he said Z06 it is an 85m MAF, also go count the MAF wires, if there are 3 then it is stock, if there are 5 wire it is an 85mm MAF
Old Jun 11, 2008 | 06:05 AM
omcar's Avatar
Well all I can say is my Granatelli MAFS works fine by 'fooling" the sensor into sensing a lean situation and fattening up the motor for additional fuel and power..my tuner confirmed this...see my sig and you will see.
Old Jun 11, 2008 | 12:13 PM
Cool, thanks.
I googled the part number and it came back a truck or LS6 MAF
It has 5 pins for the wire hookup and the part number is: 25168491
Old Jun 11, 2008 | 01:36 PM
Cool, thanks.
now i think you need to adapt your MAF 3 plug to accept the 5 wire MAF
Old Jun 11, 2008 | 01:40 PM
mycamaroSS's Avatar
the stock maf is rated at 500hp so youre fine
