Composite or Aluminium Intakes?
Anyone out there run the metal intakes? Do you have problems with heat soaking?
Your gonna get very opinionated anwsers goin in both directions. I went Aluminum b/c I do not believe the heat soak is as big a issue as some try to make others believe. I think this just for the fact that the only time air is going to be in the intake long enough to warm any is gonna be sitting in traffic & we all know you don't need max power sitting at a red light. Once moving the air does not stay inside the intake long enough to hurt performance at WOT where it matters most. Also the Aluminum will not be damaged in the case of a nitrous backfire where as a composite will shatter into a million pieces & also a Aluminum intake will stay cooler while shooting nitrous. Aluminum is also better in boosted application.
It really comes down to personal preference. Go whatever route you feel best with.
