AIR lid plug
Old Jun 13, 2008 | 12:42 PM
NJgunslinger's Avatar
Default AIR lid plug
What do you guys use to plug the hole on the Air lid after you remove AIR?
Thanks
Old Jun 13, 2008 | 01:14 PM
NBM-LS1's Avatar
Tape is a quick fix. Other than that go find a plug.
Old Jun 13, 2008 | 01:45 PM
King Nothing's Avatar
this is what i used, i can't remember what it's called but i got it out of the maintenance shop at work and it fits perfectly 1/4" in size
Old Jun 13, 2008 | 03:46 PM
Titanws6's Avatar
I stole a plug from Advance Auto, fit perfectly, it was one of those generic plugs from the miscellaneous area.
Old Jun 13, 2008 | 06:08 PM
01ssreda4's Avatar
i turned a solid PVC bar down in a lathe at work into a piece that resembled the fitting that came out of the hole. then reused the rubber gasket that was already there.
Old Jun 13, 2008 | 07:35 PM
07gsxr750's Avatar
go to the parts store and tell them u need a dodge diff plug, dodge uses a rubber plug in there diff check hole, it fits perfect.
Old Jun 13, 2008 | 07:39 PM
SweeTbone's Avatar
Go to Lowes. They have chrome plugs with the nuts and screws in the self serve drawers that you pull out. They also have all sorts of GM Fasteners too. A little RTV sealant and you're good.
Old Jul 13, 2008 | 02:04 PM
kraemer94's Avatar
I need one of these as well. I will check the advance auto parts. Would you know the part number?
Old Jul 13, 2008 | 06:00 PM
00HAWK#068's Avatar
I did the Loews thing. I got a cap that fit into the rubber gasket, its black and it looks good.
Old Jul 13, 2008 | 06:02 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs down
GODDAMM THIEF in our MIDST. [I'm telling]. [keep up that **** and there is a JAIL CELL waiting for you pally]
Old Jul 13, 2008 | 06:04 PM
01sscam's Avatar
Man-Crush Warning
I did the Duct Tape mod on mine.
Old Jul 13, 2008 | 06:07 PM
NHRAMAN's Avatar
Thumbs up
SUPERIOR RESTO-MOD for sure...
Old Jul 13, 2008 | 06:16 PM
sixvi6-camaro's Avatar
I have the Master Cylinder plug post saved...
https://ls1tech.com/forums/showpost....1&postcount=17
that is what I used as well to plug mine as well.
Old Jul 13, 2008 | 09:11 PM
BLCKBRD's Avatar
yeah this is what I used, it's a 3/4" knock-out filler for electrical boxes.
Old Jul 13, 2008 | 09:19 PM
LS1 Terror's Avatar
yah go to advance auto and go to the help section get a dodge chrysler master cylinder plug will fit perfect. cost like 5.00 but will fit awesome case closed!!
