What can I do about this? PICS
Old Jun 15, 2008 | 06:32 PM
brandon_01_ta's Avatar
Default What can I do about this? PICS
had a custom Y made the other day with the flowmaster merge and i decided to have some cats put on too... my problem is that the cat on the driver's side is right under my seat and when i get on it (at least 3/4 throttle or more) i can feel the pipe hitting the frame.... at first i thought there was something wrong with the cat but im pretty sure its just that it's hitting the frame a little... i'm afraid my welds are gonna eventually break too... here's a couple pics... what can i do about this?
Old Jun 15, 2008 | 06:36 PM
Chief Z's Avatar
Wedge a piece of high temp tubing between the cat and frame. Acts as a bumper and kills vibration into the seat pan.
I had the same problem here.
Old Jun 15, 2008 | 06:44 PM
Coy's Avatar
Coy
As I stated in another post, motor mounts are the solution to your problem. That is the only CORRECT way to fix your problem.
Anything else is a simple bandaid.
Old Jun 15, 2008 | 07:26 PM
tennz28's Avatar
I disagree with the band aid statment... My Y was also banging the floor board so I went to a shop and explained the problem. They said it could be fixed easy so I pulled it on the lift and he got the magic tool. A peice of scrap pipe! All they did was bend the section that was hitting down a little. I havent has a single bang or rub since and im on factory motor mounts. Bend that **** down a bit and you will have your sanity back!
Old Jun 15, 2008 | 07:57 PM
matt94z's Avatar
Get some poly motor mounts.
Old Jun 15, 2008 | 09:00 PM
Coy's Avatar
Coy
I am sure that fixed your problem, but simply placing some rubber tubing above the pipe is a band aid.
Also I would rather fix the problem, than lose some ground clearance.
If your motor is rocking (more than normal, or stock) THEN YOU NEED MOTOR MOUNTS.
+eleventy billion
Old Jun 15, 2008 | 10:01 PM
ok so obviously i need to get motor mounts.... the problem now is that i dont know anything about motor mounts and i def couldnt do the install myself cause i dont have access to a lift and i dont have any jacks.... so how much will the poly motor mounts cost me? and how bad is it gonna cost me to have my local shop put them in?
Old Jun 15, 2008 | 11:36 PM
matt94z's Avatar
The mounts aren't very high, but putting them in in noooo fun... Mine were a PITA, but well worth it. Not sure how much a shop would charge to do it. I did mine when I put on my LT's.
Old Jun 15, 2008 | 11:51 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I took a crowbar and yanked it down ....no cats...but it fixed the pipe banging in 10 minutes for free.....almost 2 years ago..still fine.....WORTH A TRY..it is usually only a little bit of movement that makes this happen.
Old Jun 16, 2008 | 02:25 AM
ae13291's Avatar
im going to do the motor mounts and headers, i just ordered them. but i want to avoid the banging even b4 it gets started
Old Jun 16, 2008 | 06:21 AM
Deeavi's Avatar
Poly transmission mount helped mine more than anything else
Old Jun 16, 2008 | 08:55 AM
Coy's Avatar
Coy
If you only install a trans mount with the stock motor mounts it will cause stress on the tailshaft of the transmission. FYI
Old Jun 16, 2008 | 09:12 AM
Hennytime's Avatar
ghetto-rig a piece of rubber tubing and loop it on with a cheap clamp, its like an exhaust bumpstop, that is if you care about it that bad. i just added a cam so i wouldnt feel/hear it
Old Jun 16, 2008 | 10:34 AM
9000th01ss's Avatar
If you wedge something in between the exhaust and floor it'll stop the banging but then your header will get the job of holding the engine down. Maybe it'll eventually bend down, or maybe it'll crack the tube(s) or welds.
Old Jun 16, 2008 | 12:37 PM
LS1-NAVY's Avatar
thunder racing has a thing to stop the banging
Old Jun 16, 2008 | 03:49 PM
Deeavi's Avatar
It is from Mufflex. The last time I talked to TR they said that part had been on backorder for ever.
