Help with Diagram
Old Jun 17, 2008 | 12:29 AM
Red96TA's Avatar
Default Help with Diagram
When looking at this diagram, I am assuming the fan title left fan/right fan means if you are sitting in the drivers seat correct? Or do I have that backwards? http://shbox.com/1/fan_schematic_1995.jpg
Old Jun 17, 2008 | 12:30 AM
BenLaz's Avatar
left usually refers to driver side and right passenger side...
so yes that is correct
Old Jun 17, 2008 | 12:58 AM
Red96TA's Avatar
So ok. Say I run a manual switch to the fans, do I run a hot wire to both wires coming out of the left fans connector? and the same hot wire to the first wire on the second fans connector?
