Radiator Cap Vented or not
Old Jun 18, 2008 | 08:06 PM
My1st Truck's Avatar
Default Radiator Cap Vented or not
Simple question.
I want to get new one, the current one is a 16 lbs
The parts store say it should be an 18 lbs one vented.
Old Jun 18, 2008 | 10:02 PM
Could someone just look at there stock one. My current one is aftemarket as well.
Old Jun 18, 2008 | 10:19 PM
-98-Z28-Darkness-'s Avatar
go to autozone thell tell you exactly the one youll need.... usually have the normal one and the one with the pressure relese
Old Jun 18, 2008 | 10:47 PM
noriceinside's Avatar
being that the cap is on the radiator and not an expansion tank like some other vehicles, i'd say its definitely a non vented cap.
Old Jun 18, 2008 | 10:49 PM
Thanks,
Reason I ask is I replaced the T-stat and water pump. The 16 lbs cap was on there. I swapped it for the correct 18 lbs non-vented from AZ and the main hose going into the top of the pump started blowing coolant out under pressure.
Old Jun 19, 2008 | 06:39 AM
jam01's Avatar
i never heard of a vented radiator cap. sounds like somebody doesnt know whats they talking about. i know it needs pressure and there are different lbs ratings. some have a release valve on top. if you are talking about a camaro im pretty sure it is a closed system, which means it has a fill tank and you dont add fluid thru the radiator.
Old Jun 19, 2008 | 07:26 AM
A few of the caps I looked at said vented right on them, they weren't the lever kind either.
They have something in the center that lifts.
Old Jun 19, 2008 | 12:05 PM
Went back to a 16lbs cap this morning no leaks. That was all I changed. That is a wierd one to me.
