Meziere Pump installed! Pics inside.........
Old Aug 19, 2003 | 10:03 PM
BLUEBYU's Avatar
Default Re: Meziere Pump installed! Pics inside.........
It is nice to do the work when you are doing a head or cam swap... I did mine when I swapped my heads. Also be patient and it will look pretty good...expand the braiding to it's fullest diameter and work out from the center. You also need to figure out which connection to do first...need to get the clamps reachable and hidden.
Good Luck with it....you will be happy.
Old Aug 20, 2003 | 12:04 PM
Jorday's Avatar
How much was the water pump and where can you get it?
Thanks,
Jordan
Old Aug 20, 2003 | 03:51 PM
highgmc's Avatar
got mine from summit for $499 and $8 for the stat
Old Aug 20, 2003 | 11:53 PM
BLUEBYU's Avatar
Got it from Mark at Raging Motorsports-------->
Better price than $499!!!
Call him he is getting quite a few in...in different colors...
They are going up in price from what I have heard so call him now to see if you can get one with his order...
Good luck.
Old Aug 21, 2003 | 12:34 AM
pimpmaro's Avatar
Yeah, I've seen those fake braided connectors before, but I'm interested in the real ones if it's not too much of a PITA. It would make it SOOOOOOOOOOO much easier when working on the engine... just cuz hose clamps and I have historically had some problems.... hehehe
Old Aug 21, 2003 | 09:06 AM
Reckless's Avatar
Super Moderator
Curious what kind of paint you used on the FRCs and intake. Looks almost like that anodized stuff from a can. Can you elaborate? OBTW, the WP looks awesome
Old Aug 21, 2003 | 11:42 AM
BLUEBYU's Avatar
I have a combination of real annodized finishes and the paint system from Metal Cast. It takes some time to get it right....the undercoat that gives the surface an aluminum look I used by itself on things like the STB.
Thanks for the props guys!
Old Aug 21, 2003 | 12:46 PM
Reckless's Avatar
Super Moderator
So where is the Metal Cast stuff available? Thanks BTW
Old Aug 21, 2003 | 01:31 PM
BLUEBYU's Avatar
O'Reilly's..... they have it in red also.
The base paint I referred to is called the "Ground" coat.
Old Aug 26, 2003 | 10:12 AM
tbyrne's Avatar
Looks very nice under there!!!
Here is a close up pic of the black version -
Old Aug 26, 2003 | 10:34 AM
BLUEBYU's Avatar
Thanks for the prop. I think the black is awesome!! I believe my bro and Mark are getting it in that color.
