AIR system
Old Aug 22, 2003 | 07:44 PM
WS6FirebirdTA00's Avatar
Default AIR system
what exactly does this do? and if i take it out should i get some hp gains? and would it possibly effect emission testing?
Old Aug 22, 2003 | 07:51 PM
soundengineer's Avatar
Default Re: AIR system
loose a little weight if you remove the smog pump...clean up the look of the engine bay...might see slight gain from weight reductipn and parasitic loss from the belt....
gettin ready to remove mine next weekend...need to figure out the new belt length....
Old Aug 22, 2003 | 09:56 PM
toxic99's Avatar
Air injection motor is electric, so no belt needed. The only thing you will gain is a cleaner engine bay and excelerated wear on the cats + a SES light to boot.
Old Aug 23, 2003 | 12:01 AM
[__--MUD--__]'s Avatar
you can remove the plumming but leave everything electronically plugged in and not get a code.
Old Aug 23, 2003 | 03:46 AM
SStolen's Avatar
How will losing the AIR system cause accelerated wear on the cats. WTF?
Old Aug 23, 2003 | 03:46 PM
ApacheDrill's Avatar
It helps them heatthe cats up at start up.. there for less wear on the cats. When i deleted mine, i deleted the cats and put a off riad pipe in.. I didnt care..
Old Aug 23, 2003 | 04:42 PM
so if i take off my cats i dont need the AIR system then right?
Old Aug 25, 2003 | 05:40 PM
Durien's Avatar
yeah ...the air sys is just an emmision thing and so its the EGR(if you have one)
i took them out... they are useless when you dont have cats
Old Aug 25, 2003 | 06:07 PM
You wont miss it
Old Aug 25, 2003 | 06:59 PM
so when i take it out, what all needs to come out? and where can i buy block off plates? i am gonna take out the egr also im thinking. any power gains. i know it wont be a lot if any but i was just wondering if maybe about 5hp or so lol every little bit counts
Old Aug 25, 2003 | 07:25 PM
Durien's Avatar
dont count on gaining power man... although if you havent already cut the tube part of the EGR that goes in the intake you will see better airflow into the intake .... so yeah maybe something there
Old Aug 25, 2003 | 07:47 PM
You can order the plates for the AIR and EGR from Thunder Racing, Not sure if i would say HP gains, for me it was better flow, less chance of leaks and a cleaner setup,easier to work on the engine, change plugs etc..
I changed mine out mostly because i fought my EGR tube and my intake for a long time and was always getting leaks at the intake.It is really a crappy setup and GM must have relized it when they changed the intake's after 00.
Old Aug 25, 2003 | 10:04 PM
so i take it there is no set back to taking these off....its just when inspection time rolls around im gonnahave to hook it back up right? lol but hey thats only 1 time a year....and yeah i didnt expect any power gains, but i mean that would be nice lol
Old Aug 25, 2003 | 10:11 PM
and what all needs to come out? the egr is simple. and he air pump well i knwo the pump and the tubes that run to the manifolds, anythign else? and the block off plates...does taht take care of the part on the intake too or just the exhaust. if its just the one on the exhaust how do i take care of the hole on the intake?
Old Aug 25, 2003 | 10:41 PM
Dragaholic's Avatar
9 Second Club NA
You'll need a blockoff plate for the intake too, unless you want to switch over to the LS6 intake as I did and many others. It eliminates the EGR plus results in more power especially when you start doing more mods. Ive read somewhere on here about a new intake constructed of the same material as the LS1/LS6 intakes, but Im not sure if theyre out yet and if so, if anyone is using them. LS6 intake is a good upgrade and wont need to worry about a sheetmetal one until youre running BIG cubes! Hope this helps.
Old Aug 25, 2003 | 11:19 PM
evlta02's Avatar
I would not diconnect a.i.r or egr. No horse power will be gained from removing it, only ses lights. EGR removal will result in same ses light and a reduction in gas milage at part throttle light load (highway). EGR system is not active during WOT. Beleive it or not EGR systems cool the combustin chamber during light load.
Old Aug 26, 2003 | 08:22 AM
well i was planning on having the 2 deleted out of the computer. i at least wanted the AIR out, if it is there to heat the cats and i dont have cats then why would i need it? i wouldnt need it right? and that shouldnt effect anything?
Old Aug 26, 2003 | 12:14 PM
Dragaholic's Avatar
9 Second Club NA
If you arent going to be running cats and if you are going to get both of them deleted out of the PCM, then go for it! I had my EGR deleted when I installed the LS6 intake and I never got an SES light since. I dont know if it has any affect on the emissions, but if I was to guess, the AIR would because you would then need the cats, then for them to work properly, the AIR would have to be in use.
