tpis 90mm ls6 and fast 90mm TB
Old Jun 24, 2008 | 11:27 AM
disavowed10's Avatar
Default tpis 90mm ls6 and fast 90mm TB
should i get new injectors and rails?
i dont wanna run too lean if im getting tons of more air in there.
Im just guessing that i would.
i found a good deal on the fast 90mm. thats y im getting that. i was gna get the nick williams but fast is just slightly cheaper and looks better
Old Jun 24, 2008 | 02:03 PM
JBIRD02's Avatar
You'll definately need a tune w/ bigger injectors, so if you're planning on getting it tuned anyways then throw some injectors on there, but if not, skip it til you get a cam.
You dont need rails either unless you're putting down BIG numbers.
Old Jun 24, 2008 | 02:27 PM
DonnieDarko's Avatar
You will definitely want to get a tune, But your stock fuel system at your power level should be more than adequate. I am running a Fast 92 combo on the stock fuel setup with no problems.
