smooth bellows
Old Aug 18, 2003 | 12:52 PM
Turo's Avatar
Default smooth bellows
just wondering, couldnt you make your own smooth bellow from a piece of truck radiator hose or something (instead of paying $50 for the SLP one)? i was looking around in ebay and found these for sale
click here
it looks like the guy just used a piece of hose in the right diameter, and he seems to be selling a lot fo these on ebay! what do you guys think, is the SLP one worth the $50, or have people had success making their own?
Old Aug 18, 2003 | 12:54 PM
Turo's Avatar
Default Re: smooth bellows
in case you're lazy, heres the pic of the one im talking about
Old Aug 18, 2003 | 01:04 PM
deviate42's Avatar
looks good to me?
i mean a bellow is a bellow. I think anyone could make their own.
Old Aug 18, 2003 | 01:06 PM
ChevyNo1's Avatar
Isn't there a FERNCO hose from Home Depot that works? People have been doing this since the LS1 came out I believe . . .
- Dug
Old Aug 18, 2003 | 02:08 PM
Black00Z's Avatar
- Dug
Yep, and it costs a lot less than $50......
Old Aug 18, 2003 | 02:09 PM
Danny2tek's Avatar
I got this one from Airflow Systems
Old Aug 18, 2003 | 03:54 PM
Turo's Avatar
sweet, thanks guys!
Old Aug 18, 2003 | 06:01 PM
NightHawk's Avatar
I used the 3" to 3" Fernco hose from home depot. Trimmed the top of the TB end to match the angle of the stock bellows, and hollowed out the TB end just a bit. Slid right on with a little finnesse and fit perfectly.
 Michael S. Palmer
Old Aug 18, 2003 | 07:38 PM
Turo's Avatar
nice job!
Old Aug 20, 2003 | 04:18 PM
SilverTransAm's Avatar
nighthawk, what exactly did you do? i couldn't get mine to fit over the tb
Old Aug 20, 2003 | 04:42 PM
Turo's Avatar
i just got my fernco hose. its a tight fit, so i read in another forum that the trick is to stick it in the microwave for a little while so it gets hot and expands just a bit. then install it and when it cools it should be nice and tight
Old Aug 20, 2003 | 05:26 PM
NightHawk's Avatar
I decided to keep mine out of the microwave.
I trimmed the end of the fernco that goes onto the TB from about the middle to the top, so it makes about a 20-25 degree angle. Just set it down next to your stock bellows and trim it so that the angles are the same. I also trimmed the inside of the fernco just a little, where it slides onto the TB. I think that helped a lot.
To install it, I pushed it on the TB, then from the inside of the fernco I pushed outward so that it stretched a little and slipped right over the TB (the fact that it was almost 100 degrees outside may have helped make it more pliable ). After the fernco was secured on the TB, I pushed the rest of the intake assembly (already put together) onto the fernco. It slid right on the MAF and everything pushed right into place.
I think I have a pic of the trimmed Fernco before I installed it, if that would help.
Old Aug 22, 2003 | 09:45 AM
slow's Avatar
anybodt have the fernco on a WS6?
i bought one yesterday, and was not happy with the fitment, even with cutting, it did not seem to sit right, with the raised airbox.
im running a SLP Blackwing lid as well.
Ryan.
