Anyone With True Duals 98-02 LS1
Old Aug 18, 2003 | 05:49 PM
H b K l U n A's Avatar
Default Anyone With True Duals 98-02 LS1
I am getting a different true dual then what I thought. Can you fit pipe over the left rear axle? Im running from my stock cats all the way back to bends then through bullet mufflers. I have to leave cats on because of warranty reasons. Im going to void it anyways with QTP LTs. Please let me know and I need pictures if ANY of you have pictures of your true dual exhaust setup so i can show my guy. Even if they are dumps...anything will help. THANKS!
Scott
Old Aug 18, 2003 | 06:00 PM
2002WS6_MN6's Avatar
Default Re: Anyone With True Duals 98-02 LS1
Left rear axle can be done but you have to relocate the brake lines where they bolt to the rear and be careful next to the fuel lines. You will also have to remove the panhard brace.
You can fit two 2.5" over the right rear axle (passanger side). It's been done.
Use the search feature and you will find your pics..
Good Luck.
