TSP duals with Spohn adjustable torque arm
Old Jun 29, 2008 | 07:19 PM
JASON 77's Avatar
Default TSP duals with Spohn adjustable torque arm
Is there any one that has had this combo? pics would be nice, can not get the x pipe to fit thru the crossmember for the torque arm.
Old Jun 29, 2008 | 08:39 PM
RippinZ121's Avatar
I have the duals and was thinking about ordering a TA soon...hopefully theres no problems??
Old Jun 29, 2008 | 09:32 PM
ryarbrough's Avatar
I'm pretty sure a chasis mounted ta won't work with that setup.... I've got a true dual setup on my car, and after looking at it, I'm pretty sure that you'll have to go with a long ta and a relocation setup.
Old Jun 29, 2008 | 10:37 PM
98mysticZ's Avatar
i belive bmr or umi have a setup designed around the duals
Old Jun 30, 2008 | 09:12 AM
BMR Tech's Avatar
You are correct the best option for you is a Torque Arm relocation bracket with one of our stock replacemnt type torque arms.
The long style arm used with the relocation bracket is going to great sreet/strip manners and provide plenty of clearance for the dual exhaust.
Here are a couple of images of items installed
Attached Thumbnails TSP duals with Spohn adjustable torque arm-ls1-4l60-relocation-kit.jpg   TSP duals with Spohn adjustable torque arm-lt1-t-56-relocation-mount.jpg   TSP duals with Spohn adjustable torque arm-ta001.jpg
Old Jun 30, 2008 | 09:31 AM
proelky's Avatar
I HAD true duals before I added the Spohn safety loop and torque arm. Unfortunately the Spohn setup does not clear the duals....
