JAAM “ram air” kit unplanned rain test
Old 07-02-2008, 04:12 PM
bsf
bsf's Avatar
Default JAAM “ram air” kit unplanned rain test
I installed the JAAM kit in the Spring. I removed all three baffles and am still using a paper air filter. Today I got caught in a rain storm on the expressway. I kept the rpm’s down and drove easy. I was careful to avoid hitting large areas of standing water and was not hit with too much water splashed up from opposing traffic once off the expressway. I probably drove ~15 miles over ~20min in rain that ranged from moderate to very heavy. As soon as I got the car in the garage I pulled the air filter. It was damp but not dripping wet. I saw no moisture beyond the filter. I will definitely be re-installing my K&N now that I have a proper gasket, but the kit seemed handle the rain ok. Driving in rain with the kit probably will not hydrolock your engine, but I will try to avoid heavy rain in the future all-the-same.
Old 07-02-2008, 08:15 PM
MikeG's Avatar
Yikes.
I'm gonna do the SUX2BU ramair pretty soon, but I'm gonna keep a block-off panel in the car at all times to throw under the air filter if I hit a storm.
Old 07-02-2008, 09:26 PM
Pontiacerator
RevGTO's Avatar
I have a homemade ram air setup on the standard hood - made by cutting openings in the hood brace. I did an experiment similar to yours and found water puddling on the sheetmetal under the airbox.
So I made some rain blockers that I use in heavy rain. It's a pain to put them on when it's pouring outside, but it's worth the peace of mind.
