4'' maximum flow
Old Jul 8, 2008 | 01:00 AM
dutinsss's Avatar
Default 4'' maximum flow
Has anybody used a hooker maximum flow(or maxflow?) in a y-pipe set up? I was thinking about long tubes with a 3'' ory into a 3'' to 4'' merge with the I-pipe going over the axle and then into a 4'' single inlet/single outlet maxflow muffler, dumped to the side. Basically a mufflex set-up with a hooker muffler.
Old Jul 8, 2008 | 03:21 AM
Schantin's Avatar
Good luck getting a 4" I-pipe to fit over the axle. a 3" barely clears the upper panhard rod/ fuel-tank area. You'd probably need to use a dropped panhard rod, like the UMI piece to make it work.
Old Jul 8, 2008 | 04:13 AM
Gimp98TNT's Avatar
Mufflex make a 4in cat-back, it goes over the axle.
Old Jul 8, 2008 | 06:31 PM
LS1W66's Avatar
Yeah I have the 3.5" Mufflex kit and there is still room for the 4" but it will be tight.
