Thinking about an underdrive pulley(s)...
Old Jul 6, 2008 | 05:24 PM
michaelg589's Avatar
Default Thinking about an underdrive pulley(s)...
I did a search. Found a lot about what to expect and whether or not its worth it. But, I am pretty set on getting one. What I am really wondering is which one (brand) to go with. I was seriously considering the SLP pulley with the higher retention walls. But I also saw that a lot of guys have the ASP pulley. I want to get this ordered and installed by next week, so quick responses would help. Thanks!
Old Jul 6, 2008 | 06:15 PM
Intercooler2's Avatar
Can't speak for the others but check out my thread with the Summit. Very nice unit!
Old Jul 6, 2008 | 09:07 PM
seems nice. looks a little heavier though. how are the walls on the pulley? any deeper than stock? my belt has been jumping off a little lately. I'm pretty sure i need a new tensioner. so i ordered one and will be putting it on in a couple days. but i want to make sure itll never happen. So, how deep the pulley is, is a big deal for me.
Old Jul 6, 2008 | 09:33 PM
Any Steel SFI dampner is probably going to be heavy. It looks like about 1/2" lip on the Summit piece. Don't know how deep the stocker is.
Old Jul 6, 2008 | 09:39 PM
PowerShift408's Avatar
Love my ASP. Might want to invest in a Katech tensioner at some point though.
Old Jul 6, 2008 | 09:44 PM
tillery's Avatar
Powerbond pulley here with stock tensioner. Same as SLP, but cheaper.
Old Jul 6, 2008 | 10:49 PM
Trav's_TransAm's Avatar
Im torn between ASP and powerbond.
Old Jul 7, 2008 | 11:40 AM
ssvolvo's Avatar
The Summit pulley works well for the money. It does have a slight bit of runout noticable when idling. I beat the crap out of mine constantly to 6000rpm. No problem yet. Make sure you get the smaller alternator pulley to go with it or you will have voltage problems at idle.
Old Jul 7, 2008 | 01:37 PM
Where do you get the alternator pulley?
Old Jul 7, 2008 | 02:46 PM
Kinda confusing to me that the steel underdrive pulleys are heavier than the stock one. isnt the stock one cast iron?
And who sells this Powerbond pulley?
Old Jul 7, 2008 | 03:20 PM
slobird's Avatar
I have the Powerbond pulley on my car and have been very happy with it. Same as SLP but less $$$. Got mine at SDPC along with the belts and crank bolt.
Old Jul 8, 2008 | 05:04 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Yep, we sell the powerbond pulley along with the two shorter drive belts you need and a new crank bolt. Send me a pm if you need more info!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jul 8, 2008 | 05:28 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We've got the ASP in stock also. What I like about it is that it's a good bit lighter than the Powerbond! The ASP weighs in around 8.5lbs, whereas the Powerbond is about 12lbs. That's nearly 50% heavier than the ASP
We do sell plenty of both though. Just though I'd lay out the biggest difference between the two so you have all the information
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 8, 2008 | 05:50 PM
Ouch!
You did spur me to weight a Powerbond, 10.6x pounds, that's 25% heavier. Who's counting though? We aren't in the parts business to do math. . .
j/k, friendly joking. They are both great pulleys and well worth the upgrade no matter which route you go
__________________
Old Jul 8, 2008 | 06:02 PM
I stand corrected...10.6 it is then! I haven't weighed them in ages! I don't think you can go wrong with either pulley
__________________
Old Jul 8, 2008 | 06:21 PM
bad6as's Avatar
one of you to sponcers wanna have a sale with the ASP, belts and bolt?
Old Jul 8, 2008 | 07:04 PM
bigti99a's Avatar
powerbond here with no issues on my dd.
Old Jul 8, 2008 | 07:07 PM
_JB_'s Avatar
March here, no problems.
Old Jul 8, 2008 | 08:18 PM
LS1 Freak's Avatar
I just had my ASP installed together with ported TB, gained 12rwhp same dyno, very happy with it , def. feel the difference, Big thanks to WS6 STORE for the ASP pulley, the belts you can get from anywhere
