Dual exhaust with X-pipe installed
Old Aug 24, 2003 | 04:22 PM
hugger427's Avatar
Default Re: Dual exhaust with X-pipe installed
Here is a link to some pics of mine as well. The pics suck but you can get a general look of how the spintechs look.
http://home.tampabay.rr.com/mk/true_dual_exhaust.htm
Mike, excellent look. just what I'm looking for...please get some pics when it's on a left. need to see more.
Thanks,
Ron
Old Aug 24, 2003 | 09:46 PM
Jorday's Avatar
I would like to have mine out the back, but with dual 3 inch, it would be a pretty big PITA. Has anyone been able to get it to work with dual 3 inch out the back?
Jordan
Old Aug 24, 2003 | 11:41 PM
Fierce-LS1's Avatar
Jordan
It's possible but there is really no need. Only a FI car would be able to utilize it. 2.5 is plenty for an NA motor.
Old Aug 24, 2003 | 11:56 PM
Screamin_Z's Avatar
there is 3" all the way out the back, don't know about ur kind of setup. I've seen the PHB bracket relocated and then brought out that side, so then u don't have both pipes running thru one side. I've seen them for 1200....ripoff. I've got a buddy that'll do them for $500. $250 labor and $250 parts, mandrel bent too.
Old Aug 25, 2003 | 08:28 AM
Jorday's Avatar
I have heard that the dual 3 inch is worth a little bit of power on the N/A cars. It's only a little, but it's there.
Jordan
Old Aug 25, 2003 | 11:58 AM
Screamin_Z's Avatar
I only have a internally stock 346 but I'm going to get the 3" duals out the back out of the way. after the exhaust I'll be doing a H/C swap but then after that is done I'll be saving for a total rebuild of a stout 346 turbo'd. since I'll have a 3" exhaust I won't have to worry about doing it later, just get it over with.
Old Aug 25, 2003 | 02:12 PM
Jorday's Avatar
Hey, does anyone have the hooker aero chamber mufflers with thier true duals and x pipe? I may use them instead of the dynomax turbos. Anyone know if the hookers are louder than the dynomax turbos?
Jordan
Old Aug 26, 2003 | 10:27 AM
Z28-CTYHNTR's Avatar
Sweet, bet it sounds pretty cool. I just got mine put on all the way out the back. Here are pics.
Great lookin setup man, Ive been wanting to get mine for a long while (need the cash atm). What kind of cats are you using? And how much did that setup cost you?
