Ready to do headers + duals - few questions
I've decided that I want 1 3/4 headers, coated inside and out, even though it will probably rust anyway and I'll kick myself for not getting stainless
I see MarylandSpeed has Pacesetters that they get Jet Hot coated inside and out for around $500. I think it used to be $400 earlier in the year, but whatever. There are also coated ones made by Jet Hot for around $500. Should I be inclined to go one way or the other? My impression from reading around here is that the Jet Hots are a copy of the Hooker comp headers, which are sort of a mid-range header and might work a little better than the Pacesetters (for installation, since they all have the same gains). Are there other header brands that are inside-coated I should be looking at? Am I stupid for not just paying an extra $350 for a set of Kooks and being done with it?
Exhaust tips, I'd like some Corsa clones or some sort of double-walled dual-dual tips. I saw a sponsor had them for around $50 each shipped, pretty reasonable?
Finally, mufflers... on my GTO I had an H-pipe and Spintechs and it sounded awesome. Anyone here have Spintechs on their F-body? I've seen some talk of it but nothing for sure and no clips. Guessing they would sound similar to the Morosos since they're both spiral flow mufflers?
I'm hoping my planned setup isn't too loud (at idle), I need to be able to creep through the neighborhood without pissing off the neighbors (too much).
XS headers are now the LPP headers, correct? I went to their site but I don't see any way to buy LS1 headers, where could I find a set?
As far as going over the axle, I've seen one or two setups where both 2.5" pipes go over the track bar brace on the RH side, is that what you mean? Is there enough clearance on the LH side to run a pipe that way? I thought that scraping wouldn't be a big deal because the lowest point is right under the axle, and whenever you hit speed bumps (if you go slow) it will raise the exhaust at that point as to not hit the ground.
Would have been nice if this car had duals from the factory... thanks GM!
http://s275.photobucket.com/albums/j...ent=track3.flv
this is a 3 inch dual with two sets (4 total) of louvered bullet style mufflers (stainless works brand maybe) sound quality is not great but it was prolly bc we were standing so close.
http://s275.photobucket.com/albums/j...ent=hilton.flv
Black2002ws6 sells LPP headers. Just pm him for info. And my pipes run under the axle on both sides so if I were to get it rerun it would be over both sides. I think its tricky going over the left side but it's been done. Most go over the drivers side with both pipes though. And your right about it not being that big of a deal because the rear tires hit and lift the car, but when I have 3 people in the car, I scrape sometimes. It's not that big of a deal though.
