A few LS1 swap questions?!?!?!?!?
1. I had a 3.8L 3800 II v6 in my camaro and it had electric throttle body and I am swapping an LS1 in and the throttle body is cable accuated. So would this work.....Buy a LSX throttle body that is electrically driven and add this to the wiring harness: http://www.exoticperformanceplus.com....html?item=743
2. If that isn't possible, how hard is it to add a throttle cable to the pedal through the firewall and all the other **** on the engine bay side of it then to the engine?
AND 3. What is the difference in radiator or coolant hoses between a 3.8L 3800 II v6 engine and an LS1?
Thanks in advance for the help!!!
