Percy seal-4-good issues
I took the car home anyway, and figured I'll re-tourque them after its heat cycle and cool down. Which I did, on both sides, all bolts had play and took to more torque, I snugged all the bolts, both sides.
Everyday after driving the car, I'd go back out later that night, after it cooled, and check the bolts again. Many needed more torque, but each day fewer bolts needed attention and they needed less torque to snug down.
This went on for about a week, finally all the bolts were snug and I had no leaks. It was a PITA, and I too almost went back to the GM gasket, but like you, I really didnt want to swap out the gaskets 'again', when these were supposed to be the best.
Give it time and patience, I'm sure your gaskets will also eventually seal tight.
