Oil Gauge Bad Readings?
Old 07-27-2008 | 09:05 PM
Mike Cordero's Avatar
Default Oil Gauge Bad Readings?
The RPM needle stick or rest over the oil gauge needle when I turn off the engine; do this can damage or make the gauge calibration lost?
Old 07-28-2008 | 09:13 AM
Any opinions?
Old 07-28-2008 | 03:14 PM
mycamaroSS's Avatar
dude you dont even make sense
Old 07-28-2008 | 06:01 PM
Brian2006's Avatar
Sounds like the pin has broken off that the needle rests onto. Examine close to see if the tiny plastic pin is still there or not
Old 07-28-2008 | 08:31 PM
You understand what is happening, can this be repaired? Can this situation may damage or affect the oil pressure gauge function permanently?
Old 07-28-2008 | 11:25 PM
Brian2006's Avatar
If it's just the pin, nothing can be harmed. You'd have to either ghetto rig another pin or replace the cluster
Old 07-29-2008 | 01:12 PM
Thanks again for your orientation.
