Poly Motor Mount install?
Old Aug 26, 2003 | 01:45 PM
xssive's Avatar
Default Poly Motor Mount install?
I am confused a little on this install. First, do I need smaller bolts to secure the clamshell assembly back together after I drill out the welds, or will the bolts that secure the mount to the engine hold the assembly together? Next, how can I safely jack up the drivers side of the engine? Can it be done with a floor jack and a 2x4?
Anyone have pictures?
Old Aug 26, 2003 | 02:04 PM
Fulton 1's Avatar
Default Re: Poly Motor Mount install?
The Prothane kit comes with nuts, bolts, and split washers for reassembling the clamshell after drilling out the rivets. Not sure about the ES mounts...
You can support the engine with a floor jack and a 2x4 under the oilpan without a problem.
