Hooker Headers AIR Connection popped off on the freeway...
Old Aug 26, 2003 | 04:45 PM
T/A Medic's Avatar
Default Hooker Headers AIR Connection popped off on the freeway...
On my way to work, had to get towed home. I am pretty pissed. Guess we are gonna see how Holley's / Hookers customer service is. Headers were purchased 12-2-02 and were Jet Hot Coated.
See Sig! ! ! !
Old Aug 26, 2003 | 06:09 PM
42NightZ28's Avatar
Default Re: Hooker Headers AIR Connection popped off on the freeway...
Dude i am very sorry but that is rediculous. I had heard that hookers had bad welds but that diserves a Grade A *** beating. They better cover the cost of having them removed and reinstalled for the repairs.
Old Aug 26, 2003 | 06:58 PM
B18B1LS1's Avatar
Mine did the EXACT same thing.
Jeffrey
Old Aug 26, 2003 | 07:09 PM
Go FasTA's Avatar
I've seen/heard of that happening on several different cars with several different header brands. Sorry to hear about your problems, but be sure to give them a chance to make things right before beating them up too much.
Old Aug 26, 2003 | 07:39 PM
JaSSon's Avatar
Mine did the same too. You wont get **** from them. They say the warranty is 3 months.
Old Aug 26, 2003 | 08:41 PM
2001CamaroGuy's Avatar
its not the weld, its the metal under the weld....it fractured....
note how the hole in the primary has jagged edges and no weld to be seen....then look at the AIR tube....all the weld (and part of the primary) is still on it...
Old Aug 26, 2003 | 09:06 PM
T/A Medic's Avatar
yeah your right... well fock... whats up with that. Lets hope they make good on my towing
Old Aug 26, 2003 | 10:06 PM
99 Black Bird T/A's Avatar
That sucks but it's consistant with the quality I expect from Hooker.
What kind of sound did it make when it popped loose?
Old Aug 26, 2003 | 11:56 PM
42NightZ28's Avatar
maybe for a quick fix try slapping a thin 1in band clamp on there till you can get a better set of headers.
Old Aug 30, 2003 | 08:33 PM
WILWAXU's Avatar
Saw this happen to a set of LT1 Grott's at the track. Guy used a hose clamp and a bottle cap and kept on running
Old Aug 30, 2003 | 09:04 PM
blk~2000~Z28's Avatar
Keep us informed on their service. I have the same LTs and would like to know ahead of time how HOOKER reacts to problems with their products.
Old Aug 30, 2003 | 09:48 PM
dand35th's Avatar
Well.. I will say, when I got my hookers, I had them before the '02 versions came out, and cut off the air crap and welded the holes up, then coated.. well anyway, after cutting off the air tubes, and looking in the hole, it looked like they just ripped a hole in the header tube.. not drilled, or cut.. like someone air hammered a hole in and welded on the tube.. so.. But mine are still fine now.. just some info.
Old Aug 31, 2003 | 12:27 AM
[__--MUD--__]'s Avatar
If you get stuck on some warranty hitch, I would point out that this is a major manufacturing flaw that could cause serious harm or even death as a fire hazzard, and that you can provide the names of several other people that have had the same thing happen to.
I would say you will be writing to a major magazing about this problem that you and others have experienced and how hooker responded to this situation. I've done that a few times when a manufacturer refused to ack a defective product.
You do have a good reason to shitcan the air system now though
Old Aug 31, 2003 | 12:31 AM
Smoke_Ford's Avatar
ROFL, i bet that was loud... Lucky you didnt burn a valve
Old Aug 31, 2003 | 11:43 AM
Dave Carney's Avatar
True American ingenuity!
Old Aug 31, 2003 | 02:05 PM
White98Z's Avatar
My car did the same the on the same side i just stuck it back on there and got the welder out. as a quick fix. But i no longer have them on my car becuse i thank the have poor welds. I would check your y pipe if you have a hooker to. The welds right at the y pipe were cracking on my car to.
