Blue Smoke like a Deamon
The rocker bolts need to be sealed on the intake side usually when using ported heads, did something happen there?
There are only a few ways for oil to get into the combustions chamber. From below which would be rings, from the intake which would be the PCV stuff. The rocker bolts on ported heads, valve seals when they go usually just smoke on startup. All guesses but we dont have a lot to work with here.
Figure out the PCV system. The crank case develops pressure and needs to vent it properly. Smell the smoke. What does it smell like? Sweet smell of antifreeze? Do some more examining and get back to us. Does the car have a pcv system at all or just running all closed up with he crankcase pressure having no place to go?
The big questions which was not answered are...
Did this smoke before you got to the gas station, or did it just happen suddenly after you filled up? How many miles have you put on the motor since it was in your car?
drivers cover->hard line->moisture trap->intake manifold
passenger cover->throttle body
Might try
drivers cover->hard line->pcv->moisture trap-> intake.
