should i get a 160* stat ??
Old Aug 28, 2003 | 09:47 PM
WS6FirebirdTA00's Avatar
Default should i get a 160* stat ??
ok right now im running about 190 deg in the heat here in charlotte. im getting some pinging when my car warms up. should i go to a 160? shoudl that help me out? if so where is the cheapest place to get one...sucks spending 50 bucks for that damn little thing
Old Aug 28, 2003 | 10:09 PM
onebadz's Avatar
Default Re: should i get a 160* stat ??
yea man helped me alot
also do u know where lexington is im from there
Old Aug 28, 2003 | 10:11 PM
JaxWS6's Avatar
Dang, I wish I would run 190*, I am running 210* all the time. But I'm down here in Fl. Well, from what I know(which isn't a lot!!), if you get the 160* stat, you will be running around 175*(correct me if I'm wrong) without tuning. $50 to run a lot cooler(in my case) would be worth it. Depends on what you think is worth it!
Old Aug 28, 2003 | 10:17 PM
yeah a guy i work wiht used to live in lexington. i think im going to try it out, your right 50 bucks isnt much, especially if it means saving motor problems lol thanks for the help...and where is the best place to order from?
Old Sep 1, 2003 | 01:08 AM
lsx24's Avatar
I've read that depending on your fan settings, a 160* stat will keep your engine between 160 & 170 degrees +/-. I've always wondered, is a 160* stat going to allow proper PCM operation and/or oil thickness? I've heard rumors of certain PCM events that don't kick in until a later temp, and that a 160* stat won't let it get to that temp, depending on fan settings. Is there any truth to this, or that the oil does not get hot enough for proper operation? Also I know that a 220* motor will pass emissions easier, I believe...
Old Sep 1, 2003 | 10:52 AM
JaxWS6's Avatar
Sponsors>>>>>>>>>>>
Old Sep 1, 2003 | 01:19 PM
Bad Blu Formula's Avatar
By getting a cooler thermostat like a 160, will that cause your water pump too work to hard and possibly fail on you?
Old Sep 1, 2003 | 02:48 PM
1FastSS's Avatar
Okay, a 160deg Tstat (at idle) will change nothing. The engine will still get up to the stock temp, if you still have the fans set to come on at the stock settings. The only difference is that the Tstat will open sooner, that's it. Now, if your moving down the road, have a fan switch, or have programming to turn the fans on at a cooler temp then yes, the car runs cooler. I'm in Houston and I need all the help I can get to cool the engine down. I think 210deg is too hot if I'm sitting in traffic so I got the 160 Tstat and a fan switch. Next I will be getting a gauge that shows me the actual temp of the engine (what an idea!). Hope this helps.
Old Sep 1, 2003 | 03:56 PM
1BadAzzWS6's Avatar
just get it. It's a cheap mod and it'll save you from having to do it down the road. I have it and noticed that my car does run cooler.
Old Sep 1, 2003 | 04:33 PM
lsx24's Avatar
What's the best fan settings with a 160* stat?
Old Sep 1, 2003 | 05:04 PM
so having the motor running at about 180 or 175 wont effect the operation of the pcm and what not?
Old Sep 1, 2003 | 09:35 PM
dp35thSS's Avatar
to activate the stat u would have to have the hpp3 which i have no clue if u have, but if u dont i would suggest doing the fan switch mod. i did it and it dropped me about 5 degrees during normal conditions.
Old Sep 1, 2003 | 09:42 PM
i have predator, and idea on fan temps?
Old Sep 1, 2003 | 09:58 PM
dp35thSS's Avatar
well i live in houston and its hot down here but i usually run right at 210 but after the mod i never go over about 205. it aint much man but it deffinatly does help and its a simple process. took me about 30 min. TOPS
Old Sep 2, 2003 | 02:42 AM
LS1MONSTER's Avatar
I would like to know if a 160 stat would cause a water pump to go out sooner as some one asked before.
Old Sep 2, 2003 | 10:24 AM
NHRATA01's Avatar
The water pump's operation is independent of that of the thermostat.
Old Sep 2, 2003 | 11:48 AM
1FastSS's Avatar
The water pump works the same no matter what Tstat you have installed. The only difference is when the coolant starts flowing thru the radiator......
Old Sep 2, 2003 | 11:56 AM
so if the fan temps are changed inthe computer the computer should still operate the same and it should effect how anything else runs right?
Old Sep 2, 2003 | 06:26 PM
1RawTA's Avatar
yea i was thinking about getting the 160 degree thermostat also.. im in nj and my car is running like 210 also, will it need pcm tuning if i get the stat?
Old Sep 2, 2003 | 08:20 PM
yeah if you want it to run colder you need to adjust the fan temps
