Cars not running right! Help please
Old Aug 10, 2008 | 11:44 PM
Skeet Skeet's Avatar
Default Cars not running right! Help please
So i was leavin work today and went to start my car and i noticed something was wrong with it as soon as i started it. It started to bog a lil bit. The rpm's wouldnt level out they kept on dropping to around 350 to 400 and then bck up to 700 or so like they should be. It drove home just fine except when i put the clutch in and let off the gas it dropped off again and kept wanting to die again but it drove fine and reved fine when ever i did give it gas. I was thinking it mite be the fuel filter but not to sure. Also the check engine light was off and it should be on right now. I just got longtubes installed with an off road y and it hasnt been tuned out yet so please any help would be greatly appreciated. Thanks guys
Old Aug 11, 2008 | 12:51 AM
CAMAROZ28SS's Avatar
no service light? i dont think it would be the 02's then. make sure you dont have any wires on the header tube.
Old Aug 11, 2008 | 10:26 AM
Ok will do but its weird because the light is supposed to b on and its not. Im gna try and take a look at it today when i get home from work. thanks a lot
Old Aug 11, 2008 | 08:19 PM
also check to make sure your plugs are tight and the plug wires are on all the way. also if you deleted the AIR/EGR make sure you plugged the vacumm lines (that should make it run to shitty but its important.
goodluck let us know what the problem is
