I think I got screwed please help
Old Aug 14, 2008 | 11:09 AM
sevenstarsfall's Avatar
The ls1 and ls6 oil pumps are the exact same and as for the ls2 chain it should appear to be a lil thicker like previously mentioned.
Old Aug 14, 2008 | 11:53 AM
AMitc31100's Avatar
so just went out and checked. 60 at startup and once it warmed up it was around 55.
Old Aug 14, 2008 | 01:14 PM
toneloc60's Avatar
Originally Posted by AMitc31100
i don't know if i should ever buy an ls6 oil pump then if you gain 10-15 psi. right now my car runs at about 60 psi just idling. does that seem a little high?
No, it's not high. It's really only above 80 PSI that oil pressure becomes an issue.
If it's above 80 PSI during a pull I'd look into changing the spring for the relief setting, or cutting a couple coils out of the one in the pump.
I had REALLY high pressure in my 441 LSX. I was using a Melling high pressure and hihg volume pump and saw 130 PSI while running 20W50 on the dyno for break in. I pulled the pump, cut the spring and dropped to 5W30. It is still a little high on start up but never peaks over 80 PSI during a pull after the oil temp is above 200*.
