Oil sending unit
Old Aug 28, 2008 | 11:55 PM
BradsLS1's Avatar
Default Oil sending unit
Can you guys please tell me where that oil sending unit is? I'm pretty sure I have a bad knock sensor. I say pretty sure because thats what the scan tool said at good old Autozone. I'm not really going to believe them until I have a friend of mine hook up a real scan tool and go through the troubleshooting with me. Anyway if I have to end up having to take the intake off I don't want to brake anything so where is this oil sending unit that I should be worried about. It is a stock intake. Oh can I reuse my intake gaskets or do I need new ones.
Old Aug 28, 2008 | 11:57 PM
BradsLS1's Avatar
Oh and do I need to get a special socket for the knock sensors or will a regular deep socket work? Do I need any special tools to take the intake off like a special tool for the fuel lines. Or can I leave them on and just move the intake out of the way?
Old Aug 29, 2008 | 12:04 AM
Havok956's Avatar
i just did this to my car. The oil sender is right behind it. As for removing it's all fairly easy till you get to the last 4 bolts on the intake in the back. I had alot of problems with it. Fuel lines easy also
Old Aug 29, 2008 | 12:13 AM
BradsLS1's Avatar
Ok so how to people end up braking them and do you need a special socket for the knock sensors and do you need that fuel line tool I forget what they call it. Or like I said can you just leave it hooked up.
Old Aug 29, 2008 | 12:18 AM
Havok956's Avatar
You just have to be really carefull when you start pulling the intake towards you cause some pipes may get caught with the sending unit and yanking it off. I didn't mess with the knock sensors on mine. and as for fuel lines i just used wrench and socket to loosen bolts then pull from the rail to get them off. They come off as a pair. and you will have to take them off if you need the intake off
Old Aug 29, 2008 | 07:43 AM
Mart00SS's Avatar
Try using the search, there are so many pictures and info on this.
Here is the link to Havok's thread about the OPSU. Look at post #9 by me there is a pic of the Oil Pressure Sending Unit.
https://ls1tech.com/forums/generation-iii-external-engine/977016-help-intake-install.html
