map/baro circuit?
Old Sep 9, 2008 | 05:20 PM
JASON11WS6's Avatar
Default map/baro circuit?
I just installed a LS6 intake and some headers on my car and got this code (map/baro circuit low imput). Also got the EGR flow sensor A circuit low imput at well. The EGR was removed for the LS6 intake so I know I'm good there. But the Map/baro circuit I'm not positive about. I would assume it's just a sensor I didn't plug in since the code was worded with the same low circuit imput. Could be wrong but just wanted to get some imput. Pretty sure I did leave a connecter unplugged somewhere in the back of the manifold. MAP sensor is Manifold Air Pressure correct?
Old Sep 9, 2008 | 08:18 PM
ramairracer's Avatar
yup that connector behind the intake was for the map sensor, and then you have the cam sensor and the oil pressure sensor
