true duals all the way out
Old Sep 10, 2008 | 10:46 PM
shtnfrds's Avatar
Default true duals all the way out
so i'm getting pretty sick of the insane amount of drone haveing a TD setup. They dump right before the rear axle, i dont actually know if its the mufflers that are causing the drone or if it where they dump. I was told they are dynomax's. If i were to get a shop to run pipes from where they are now out to the bumper would it at least help the drone issue or should i look ino a y-pipe catback setup?
Old Sep 10, 2008 | 10:52 PM
SoxXpupPeT's Avatar
if you have the pipes running ou the back it should help it out alot. maybe put your mufflers in the back after the axle. theres no point in going to a single 3 from a TD set up. just get that out from under the car
Old Sep 10, 2008 | 11:56 PM
shtnfrds's Avatar
no i didnt mean to go single 3, i would keep it duals all the way back, i have however heard it's kind of a bitch to get it done tho.
Old Sep 11, 2008 | 12:58 PM
adam02gt's Avatar
Tailpipes should help it not drone as much. Have you thought about adding another set of bulletts into the tailpipes?
Old Sep 11, 2008 | 06:00 PM
mcalus's Avatar
Yes it will help a TON! It will be sooooo quite in your car but still loud as can be outside, take it to an exhaust shop they should be able to run them over the axle and out the back around 200 w/o tips.
Old Sep 11, 2008 | 08:48 PM
*98TransAm*'s Avatar
+1 if you dont want to spend to much money to quite it down.
Old Sep 11, 2008 | 08:51 PM
King Nothing's Avatar
it helps TRUST ME!!!! no it's not hard at all and it looks bad ***!!! i get compliments all the time for how my exhaust looks
