Would this cause my belt to come off?
Old Sep 16, 2008 | 06:08 PM
razorclaw99's Avatar
Default Would this cause my belt to come off?
Have had a few belt incidents. Once i started my car and the belt just shot off. And a few times separated by months apart, i was at WOT and when i let off i realized i had no power steering. (aka belt is off)
so heres a pic of my tensioner..would like to know if its bad. it looks a bit crooked..
Old Sep 16, 2008 | 06:39 PM
nemss1's Avatar
tensioner could be weak
Old Sep 16, 2008 | 07:39 PM
ramair21's Avatar
it might also be the crankshaft pulley. I read around here that this happens. It happened to be once. But anything is possible
Old Sep 16, 2008 | 08:43 PM
DrkPhx's Avatar
Get the Katech tensioner to replace the stock unit. It prevents belt slippage which causes shredding at high rpms.
Old Sep 16, 2008 | 08:51 PM
fatdave's Avatar
can you move the tensioner by hand? I would recommend a manual belt tentioner. I plan on getting one soon for my car as I am now spinning to 6500
Old Sep 16, 2008 | 08:57 PM
SweeTbone's Avatar
I got a shorter belt for the short term with my ASP pulley and stock tensioner. A 76" belt (4060760) was slipping and throwing at high RPMs but a 75.5" belt (4060755) has stayed on with no signs of going anywhere. I lost my 76" belt on a spirited highway on-ramp blast and no power steering and a CHECK GAGES light was on telling me my volts were at like 10. Haven't had any problems with the shorter belt, but still plan on buying a Katech Tensioner just for good measure and peace of mind.
Old Sep 16, 2008 | 10:00 PM
so should i just get a new OEM tensioner or a 75.5'' belt verse the 76'' ?
Old Sep 16, 2008 | 10:05 PM
conan's Avatar
have you had the crank pully off recently?
Old Sep 16, 2008 | 10:41 PM
yep..for a cam install
Old Sep 16, 2008 | 10:55 PM
conan's Avatar
You might not have the pully seated all the in to the engine. just some thing to check.
Old Sep 16, 2008 | 11:01 PM
but does it look like my tensioner is a bit off..not lined up?
Old Sep 16, 2008 | 11:11 PM
conan's Avatar
The gap at the top does look bigger than the bottom of the tensioner. I've had problems with seating my pully before and I wasn't tossing belts but it was moving off the engine a little. just some thing to check before you drop the $$ on a new tensioner.
Old Sep 17, 2008 | 12:13 AM
JGKadell's Avatar
I had it happen to me with an ASP pulley. The pulley separated and slid back some.
Old Sep 17, 2008 | 03:19 AM
so if i check the crank pulley and tighten the tensioner bolts and it still does it. Should i go for a new tensioner or 75.5'' belt..as opposed to the standard 76''
