which pushrod with this cam?
If you mill the heads or get a different thickness head gasket thats when its best to get a pushrod length checker that way you can be dead on.
The cam does not make a difference to the actually pushrod length.
If you want you could also get 7.425 pushrods, which is what I did. Because they are just a hair longer it helps to quiet the valvetrain down a little. If you do a search im sure you will yield some good results with the 7.425 pushrods.
Looks like a good cam you got there
