lift engine for long tubes?
both went in and out easily but you need to get the nose up high. drive the car up on ramps. wheel **** the back tires. now either platform a jack or if you car jack goes high enough just jack the car up from the k-member. get it up there! place your jack stands at both front end of the frame rails. lower jack just enought to get weight on those jack stands. proceed to do the job.
theyll fit in easier if you can turn them vertical when installing. dont forget to unbolt your manifolds before getting the car off the ramps(otherwise u need something to stand on) i left the old plugs in to hang the header on. and just a hint....... number 8 plug and wire is simple to get from under the car. good luck
I dynoed at 347rwhp with long tube headers running through a jet hot y pipe and and open exhuast cutout, only other things done were air lid and ported tb. So you definitely gain a good amount of hp from lt headers and a tune.
I didn't even have to remove the sterering shaft, as someone else mentioned.You will need a Y-pipe for all the headers available (less shorty).
