drivers side lower alt bracket?
Old Sep 25, 2008 | 01:06 AM
87olds442's Avatar
Default drivers side lower alt bracket?
hey im a noob here and i recently purchased a ls 376/515 . i was searching on here for a alt bracket that i would be able to use to locate the alt on the lower drivers side. i have seen that bmr offers one but the say its for use with a electris water pump which i will not be running . i was wondering if anyone has or seen someone running that type of setup with the ater pump or would i have to fab up a few idler pulleys to make that one work any help would be apprieciated..
Old Sep 25, 2008 | 07:18 AM
GA95DCMSS's Avatar
You should be able to use the stock LS1 alternator bracket. F-Bodys come with them in that location from the factory.
You can see it on the bottom right of the pic i uploaded.
Attached Thumbnails drivers side lower alt bracket?-0611_ghtp_62_z-ls1_engine_build-engine_accessories.jpg
Old Sep 25, 2008 | 09:14 AM
87olds442's Avatar
thats what i was thinking about and maybe get a idler puller for the pass side .. maybe ill call a few junk yards and see what they got . thanks
Old Sep 25, 2008 | 03:54 PM
GA95DCMSS's Avatar
if you can't find it at a junkyard, look online or ebay. they usually run $25~. I'll send you a pm about another good place, seeing as they aren't a sponsor.
