header problem need help!!!
Old Sep 25, 2008 | 06:36 PM
rice4eatingnotdrivin's Avatar
Default header problem need help!!!
So i recently bought a set of flowtech headers... after i get the passanger side header installed i start putting everything back together when i notice the drivers side header is hitting my K memeber... not that big of a deal so i notch the k member out a little.. then i come to a HUGE problem... there is AT MOST a inch of room between the o2 bung and the frame... u cant even come close to putting the o2 in... what the hell should i do... i really dont want to take it back out and go through all the bullshit of putting it in again... any suggestions would be great thanks guys
Old Sep 25, 2008 | 07:04 PM
Grimes's Avatar
you could plug that bung and install a new one further down or on the other side....may work, but ideally you want the O2 to be as close to the primaries as possible
Old Sep 25, 2008 | 08:24 PM
i was thinking about doing that.... but another problem i found is when the motor is reved the header hits the floor.... talked to flowtech and they told me they had some problems with a few sets of headers.... told me to pretty much send them back where i bought them and get them exchanged..
Old Sep 25, 2008 | 09:35 PM
SS1875's Avatar
but damn on the X-ray in your Avatar!!!
Old Sep 27, 2008 | 05:27 AM
lmao that is my leg to no joke either.... y i bought a ls1 and stopped racing motocross well i didnt stop i just dont race as much anymore
Old Sep 27, 2008 | 11:10 AM
MarylandSpeed's Avatar
Wow...that is one scary leg!
Old Sep 27, 2008 | 11:54 AM
Deerhunter-Z28's Avatar
I feel your pain man, I just put some used jet hots on and I had to notch my kmember, no problems with the 02 bungs, but I would do what someone has already suggested, plug them and install another bung.
Old Sep 27, 2008 | 02:48 PM
i agree with that. im going to but im waiting for my Y pipe to arivve to make sure everything lines up b4 i go putting a new hole in the header... otherwise if i do that and it doesnt line up flowtech probably wont help me out if it is from them setting up the jig wrong when it was made
Old Sep 27, 2008 | 02:50 PM
ya its scary but chicks dig scar's
Old Sep 27, 2008 | 03:10 PM
Vndcatr's Avatar
i had the same issue with my flowtechs back in the day.. I just ended up deleting my 02 sensors in the tune.. Your car will run fine without them for a few days until you can get it tuned... But yea there was no room in there..
Old Sep 27, 2008 | 04:27 PM
torquejunky's Avatar
Ummmmm, you need the upstream O2s.
If you are impatient, you could take the header to a shop that has a real nice mandrel bender and get them to bend it into shape. However, if Flowtech told you to send em back, that's gonna be your best option. You just have to be a little more patient with the second option, good luck.....
